Originally Posted by
Kawar Small update for everyone still need help but whatsapp has told me there log files I keep sending so they have frash ones to work with keep telling them there's transcodeing errors. But i upload the same video to snapchat as a test and it works fine.
If i may or may not have transcode problems do you think i should Uninstall all whatsapp files from my phone and restore from a back up and then if that is no help.
Do you tbink resetting my network settings will do anything?
Definitely give it a try , if that doesn't work can clear it's data and cache, then force stop WhatsApp
