Samsung S21 Ultra Has No HD+ Call Sound on 5G Network
spartanmike1
I have spent over an hour on the phone with T-Mobile and Samsung support and gotten nowhere so I will try with the knowledgeable people here.
When connected to a 5G network, my new S21 Ultra will not make calls with HD+ sound quality. During a 5G network call, the HD+ icon is not present on the call screen and looking at the Service Mode (*#0011#) invariably shows that the sound codec is "AMR:NB" which is the narrow band relatively low quality call sound. However, if I go into mobile network settings and put the phone in 4G network mode and call on a 4G network then calls do have the usual T-Mobile HD+ sound and icon present and the Service Mode shows the sound codec as "EVS:SWB", all as expected for HD+ call sound quality.
Any thoughts on what is going on with the missing HD+ call sound on 5G network? Does T-Mobile 5G, or any 5G, support HD+ call sound?
Us a new SIM card needed? Did you rule that out?
Just guessing while doing a little googling about 5G VoLTE.
I would make sure your old phone with the same Sim works before getting bent out of shape over it.
Is it possible they assume that any call made or received on a 5G network is already HD+? Thus, any such additional designation would be viewed as redundant?
Just a thought.
thevault12
