smooth4lyfe
Trusted Member
- Sep 16, 2012
- 5,534
- 0
- 0
actually the problem is that this spam pops completely on random basis. i've started receiving them after some "quite" period, before or during which i did not install any applications for at least 4 days. i'm thinking its some malware which could not even have own icon in the apps menu. i guess we should all be careful while browsing web.
- Check the reviews of recent apps you have downloaded and see if people say it brings ads to their phone, that would tell you
- Use Trustgo Anitvirus and enable all options
I have Airpushed ads on my phone that appear randomly which do annoy me...according to Airpush, its 2 apps, but im sre its more than that...I usually check the reviews to see what apps are causing it
