Forgive me if this has already been posted before, but I'm extremely frustrated. I have a Samsung Galaxy S3 LTE i9305 running Cynaogenmod CM10.1.3 with yank555 kernel. I have just purchased a 4500 MAH lithium-ion extended battery for my phone and it doesn't seem to be working as it should. Correct me if I'm wrong, but I expected between 12-18 hours of moderate to heavy use with the screen continuously ON, mobile data ON, playing games, music, etc. Instead, what I'm observing is that after 34 minutes, the battery has gone from 100% to 7% with the screen on the whole time reading with Google Books. Bluetooth and GPS and locations services off brightness turned down.
I should also note that I have the apps Twilight, Dropbox, Facebook, Twitter, Viber, etc running in the background. But I was under the impression that this shouldn't matter and the battery would take MUCH longer to discharge. For example, when I was running stock rom on the Samsung 3000 MAH extended battery, the battery would on average, go down by 10% per hour with CONTINUOUS screen on time and making calls, emails, music, etc, therefore in ten hours the battery would be completely drained. So I expected this THICKER LARGER extended 4500 MAH battery for the S3 would be at almost double that. I should also NOTE that if I leave the device IDLE and do not use the phone at all, it would last very long, but I got the extended battery for continuous use with the screen on.
I thought maybe the battery is not being indicated properly so I used the Battery Calibration app to try to calibrate the battery so far that doesn't seem to have worked either. Could anyone offer me ideas why an extended battery is not lasting much longer than the stock samsung battery which is only 2100 MAH? The reason I got the extended battery in the first place was because I found the 3000 MAH battery wasn't lasting long enough.
