Is anyone else having audio clipping at higher volumes with an equalizer enabled? The stock equalizer does it as well, but I usually use https://forums.androidcentral.com/e...xoidelabs.eizo.rewirepro&hl=en&token=r0M2QOBk and it does it as well.
Works perfectly fine on my note 2. Just trying to see if I have some defective hardware or something.
Thanks
Thanks
