What happened to my battery stats... Its gone!
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
Phone is running perfectly, so I went to check my battery stats and find nothing is there! I have restarted and still gone... Anyone know why?
Sent from my Galaxy S4 Exynos!
zkSharks
Retired Moderator
Mar 15, 2011
2,013
75
248 days of CPU activity? How long exactly have you had this phone? :p
Edit: I have little advice other than that something must have happened to the battery stats file. The only method I'm aware of to fully reset that file is by wiping battery stats in a recovery.
zkSharks
Retired Moderator
Mar 15, 2011
2,013
75
Lol I really dont want to do that...hopefully it will come back on its own
Is there an app that can show me screen time?
Wiping the battery stats affects nothing except the statistics you usually see there. There's no impact on battery life/performance.
Apps such as BetterBatteryStats, CPU Spy, etc. often include statistics about screen time, though I believe they are accumulated via the same means as the system battery usage log (meaning the same issue may or may not manifest itself in some way in those apps).
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
Ahhh got it, can u show me how to do that?
I'm guessing I have to go in Recovery Mode on the phone?
zkSharks
Retired Moderator
Mar 15, 2011
2,013
75
Yep. It's usually under advanced/more options somewhere I think. Been a while since I've done it since it isn't necessary unless there's an issue with the battery stats reporting.
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
It actually fixed on it own...all I did was charge the phone back to 100%....weird
It probably reset the stats
zkSharks
Retired Moderator
Mar 15, 2011
2,013
75
As far as I'm aware, it doesn't reset the whole file, but it does in effect 'reset' the charging cycle it's on. So you get fresh numbers. May be wrong.
Glad it got sorted out. :)
smooth4lyfe
Trusted Member
Sep 16, 2012
5,534
I am wondering this myself also ...... He just got the phone recently unless is an error in the stats.
I got it when I met the president of Samsung like 248 days ago... He told me not to tell anyone that I had the phone though so I had to keep it secret
danishpeer
