Jennifer Stough
Retired Moderator
So basically, it does all the things I do already, except it takes up some space on my internal memory
Pretty much, and it take a week to "learn."
Sent from my HTC6435LVW using Android Central Forums
Ok so perhaps I'm going to sound totally foolish on here. But I've been an avid iPhone user for the past two years and recent decided to switch to something more...advanced. Enter the S4. I consider myself a fairly heavy user, constantly checking twitter and FB, pic taking and editing, and music, glorious music! And I've noticed that my battery even though its brand new (I've only had this thing three days) is pretty much draining in front of my eyes. I'm not used to having to constantly shut off apps and stuff. Is there anything I can do to keep this thing from becoming a battery draining monster while still maintaining some semblance of my version of "normal" usage?
What is snapdragon guru?
Snapdragon battery guru, its an app in the play store.
It's a power saving app with features that QUALCOMM designed specifically the snapdragon CPU. It's found in the play store for free. I used it on my S3 and it made no difference but haven't tried it on the S4....
Is it any good?
It learns the pattern of your WiFi and data useage and turns them off accordingly to try to spare battery.
Today I turned up the brightness on my S4 and turned on location services, and the battery started dropping.
Turning off location services and dropping brightness and I should be back to a solid 8+ hours of battery with heavy usage (phone, text, internet.)
So what is turned on really matters.
He's mine for today.
Sent from my SCH-I545 using Tapatalk 4 Beta
How long does your battery last for? how long do you spend on your phone?
I have a higher mAh battery fitted,thicker so has a replacement back,lasts over two days with moderate use,plenty on ebay but BEWARE the "Gold" make,their not what they claim,seem to be regular battery relabeled higher mAh
Turned off all the novelty and I'm running on over 30 hours without charging, last time I had a phone that stayed charged for that long was when Clinton was president! Also, taking a screen shot has never been so easy!
