Need someone smarter than AT&T to figure out malware issue on Samsung S4
Awhile back I may or may not have click on a "fake google play store" and possibly updated an app. I don't know which one. Something hijacked my certificate approvals and is giving them to apps that look like they are legit but are not. After lots of trying I took it into my service provider who tried a factory reset which did nothing. My phone was sent into AT&T and my SIM brand new SD card trashed. I received a completely new phone (same model) sometime later and was given a new SIM card. They kept my same phone number. At first it SEEMED okay, but I was a little skeptical of the AT&T update running constantly in the background and a few other weird things. I used it slowly to see if it was really fixed. I even made a new gmail address (because you need one for everything). Adding a gmail account to the phone seemed to make everything go to crap again, even before I did anything with it. I removed the google account and did a factory reset but problems remain.
Some of the more serious issues have been:
bogus certificates giving insane permissions to lots of random apps
not being able to disable/truly stop apps (if I do they usually pop back up or run in the cached processes i.e. background)
having the camera, microphone, wifi, screenshot functions act on their own (it's a real safe feeling)
I'm unable to use the Security setting "verify apps" or "Clear credentials"
I've only had this phone since this fall and it's been a nightmare. I'm not stupid about web stuff and am probably more careful about security type stuff than most people (never used a credit card on it, installed facebook, etc.)
Allegedly I'm running Android version 4.4.4. I have some other crazy stats if that will help. Running a software update previously didn't work because 'this thing' has control of that too.
This is a lot of b.s. for a phone that isn't even considered close to new anymore.
Help!
Help!
