Phone calls drop when I use the Network mode with auto connect in Samsung S5 mini SM-G800F
Hi Community,
When I configure my Samsung mini S5 SM-G800F in Settings/More Networks/Mobile Networks/Network mode in (LTE/WCDMA/GSM auto connect) or (WCDMA/GSM auto connect) the phone calls drops. If I configure my device in WCDMA only or GSM only the phone calls works fine. As you can see, the "Auto connect" function it's failing during a call, because you can see the H in the signal type, and before the drop you can see the signal type changing to 3G.
- The LTE and WDCMA bands works perfect with data.
- I have tried a friends sim card and the behavior it's the same (i.e. not my sim)
- I am on latest IOS (KitKat 4.4.2)
It's not under my network operator warranty because I bored the device in Amazon, so I know that it's a device issue, hopefully something that I can change in android or changing the AP version.
Cheers for any help -greatly appreciated.
Hi Community,
