Try factory resetting it and observe using gsam. Just install a few apps.
Sent from my HTC One_M8 using AC Forums mobile app
Turn Ultra Power Saving on when not running apps. You can still have phone calls and messaging active in that mode. I only have to charge my s5 once per week.
I'm constantly using apps
Then turn on Ultra Power Saving when you sleep. It could double your battery life.
I turn the phone off when I sleep and also use battery doctor even thought im not sure if it helps but I like to believe so.
What do you mean by just install a few apps? Thanks guys. Is there any other reasons its draining a lot faster than 2 days ago? My wifi seems to be cutting in and out for a few seconds constantly. Does that have something to do and what causes the wifi to do that?
Probably the juice defender. Its 8:24 p.m. And I still have 60 percent battery. Its been unplugged since 7 a.m.
