Hi there
I need help please. In the past week my battery life has dropped considerably, caused by a gpsd process running constantly.
Following advise from other forums I did a factory reset (twice) on the phone and stopping any updates on Apps that are pre-installed on the phone. I also did not load any extra apps to see if it is not a 'rogue' app causing this process to run. I also deactivated the location setting/gps and did not activate any Google accounts.
And still I cannot seem to stop it. Battery life is now about 8 hours from fully charged on less than normal usage.
The phone has got the latest updated software on board.
Attached is a screenshot of this damn thing sucking my battery dry :'(
Any advice will be appreciated
