Those of you who have 'L' or Lollipop already installed, would you please post if the following is true?
I am very concerned over not being able to control WiFi or the Data radios.... this is a deal breaker for me on Lollipop. If I can no longer turn the data radio off, I am going to have to find a way to prevent the upgrade from happening.
KNOWN PROBLEMS: * On Android 5.0+ the "Disable mobile network" function does not work (the mobile data switch widget and the auto-disable feature are both affected). This is because on Lollipop the enable/disable function is no longer accessible to third-party apps.
The above statement came from this Dev's app page notes:
* 3G Watchdog - Data Usage - Android Apps on Google Play
