- Jun 24, 2016
- 56
- 0
- 0
The phone still works great but it is time for a new battery as a charge only lasts a few hrs. After combing reviews for days, once you get past the BS 4 1/2 stars, there are many bad reviews of early failure, little capacity, over heating, etc. Apparantly, most or all of the OEM labeled batteries are fakes or not worth a darn. Samsung no longer supplies S5 batteries directly. Anker used to make a good replacement but it is no longer available. If anyone has a reliable source for good batteries I would be grateful for the information. Thanks.
