Samsung Galaxy S6 Edge Plus not charging by port only wirelessly
ryandroid96
8
so last month i plugged my s6 to my friend's ps3 after i left his house i went to my dorm and plugged in my phone to the wall charger it worked fine till i woke up next morning to find out that my phone wasn't charging,i plugged my phone to my laptop and it showed "unrecognized USB" it didn't charge at all tried usb debugging,5 times factory reset soft and hard and nothing helped;Now here's the strange part i placed my phone on the wireless charger it worked but then i plugged my phone's usb cable to the laptop at the same time and my laptop recognized my phone too,so how can i bring back my phone from charging on port (NOTE:BATTERY CHARGES FINE ON WIRELESS AND DOESN'T EVEN DRAIN)
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
Welcome to Android Central! First, make sure the microUSB port is completely clear of debris. Use a can of compressed air to blow it out.
If it seems clear, then have you also tried different USB cables? If different cables also don't work, then the port itself might have failed.
ryandroid96
8
cleaned it multiple times and have used different cables also my vr is not working with it when ever i plug it into the vr a black screen with a small x appears and after 3 seconds it returns back to the homescreen
Morty2264
Ambassador
Mar 6, 2012
22,922
1,053
113
Perhaps bring it to your local carrier or to a cell phone repair shop of this issue is persisting. How long have you had the device - is it under any kind of warranty?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
Yeah, if it's happening in Safe Mode, it's more likely to be a hardware issue, specifically with the port. That part might have to be replaced.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,606
4,756
113
It's possible for the microUSB port's charging contacts to be damaged, but the data transfer contacts to be intact. That might explain your situation.
ecstasy89
