Jaycemiskel
Trusted Member
The mophie looks better than this to me.
I'm really leaning towards the Mophie, but what do you guys think of this one? It's just so cheap. http://www.amazon.com/Comsoon-Recha...ag=hawk-future-20&ascsubtag=UUacUvbUpU4382060
The review for that first one says that it's a little loose when used with an edge. See, that's the type of stuff I'm worried about.I was thinking of either this one:
http://www.amazon.com/Battery-Exter...ag=hawk-future-20&ascsubtag=UUacUvbUpU4382108
Or this one:
http://www.amazon.com/Sykiila-Recha...ag=hawk-future-20&ascsubtag=UUacUvbUpU4382108
Or maybe this one:
http://www.amazon.com/4200mAh-Porta...ag=hawk-future-20&ascsubtag=UUacUvbUpU4382108
Has bigger battery. Might go for one of these ones.
Heads up - for those looking here to discuss a battery case for the S6 instead of the Edge, ZeroLemon has its S6 case on sale on Amazon for $19.99. ZeroLemon Battery Case 50% off @ Amazon - Android Forums at AndroidCentral.com
-= Cheers! =-
I'm in the same boat. I just wish that Verizon already had the edge Mophie available to order. They don't even have it listed yet.True, for $20 its cheap, but for me Fug is Fug and my Edge will not be Fug. Plus I can get 25-30% off with corp discount so I can a bit.
The case is Not released until later this month of JuneSo I ordered my Galaxy S6 Edge Mophie extended battery case April 14th and still don't have it. Has anyone here received their Edge case yet?? This is ridiculous!
