I've looked on several sites for a privacy screen protector for the galaxy s6 edge. No luck...they all do not cover the full screen even when they say compatible in the description. Does anyone know where I can find one?
Hi tbh with you, you are better off getting an S6 edge tempered glass screen protector, it covers the whole screen, and they are perfect, I've got one on mine and they are a lot easier to put on than the normal screen guards, hope that helps. Oh yh go onto eBay they have lots of different ones and colors, the item number is (231805589312), the sellers name is m-f15, his ones are the best ones I've came across on there.
