how can upgrade my s6 edge smg925a from atyt?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
That's the AT&T version, right? Are you on AT&T or a different carrier now? System updates for carrier-specific phones typically require you to be on that network in order to receive the official OTA update. If you're not on AT&T, then try using Samsung Smart Switch to update the firmware.
