Please Help! Why is it only GSM mobile data will work in my Galaxy S6?
rony0505
14
Please Help! ONLY GSM mobile data works in Galaxy S6
Dear All,
I am here with the expectation that my problem can be solved. I am using Galaxy S6 (G920F) Duos. When I bought this phone my OS was 5.0.2. And then one small update happened from OTA. After that I am not able to use LTE/WCDMA. Recently I installed a new update OS 5.1.1 and the problem is stayed with the phone. When I select LTE/WCDMA/GSM (Auto Connect) or WCDMA/GSM or WCDMA then there is one error message "Not registered on network" and "Emergency calls only". When I select GSM only then all the call, message & mobile data is ok but with 2g speed (Slow spped internet). Can anyone help me to suggest any solution to get rid of this problem. I tried service mode to change the band by typing *#2263# and there is a option to change the band but nothing happened. No 3G connectivity is there. Please help.
Fred Wilson2
231
Re: Please Help! ONLY GSM mobile data works in Galaxy S6
The clue is probably the message that you get "Not registered on network". Sounds like your carrier doesn't understand that phone pings.
Try calling them and having them add your phone/IMEI.
Fred
rony0505
14
Fred
Thanks for the reply. Actually I talked with them and they dont have any option to include or exclude of my phone/imei. Is there any other option to do so?
rony0505
14
My apn is ok as per my mobile operator. Is there any network lock or modem upgrade issue?
rony0505
14
What should I choose in service mode? Band selection and HSPA setting for 3g network.
Fred Wilson2
231
I would contact your carrier again and ask them why "THEIR" network replied ""Not registered on network"
Fred
rony0505
14
I am from Bangladesh. Which country/carrier Firmware I should install in my Galaxy S6 (SM- G920F) DUES? Please suggest.
mashtatz
Hi did you manage to sort this problem out? as having the same trouble with mine now :'(
AmeliaRodriguez
