I am looking to buy a desk stand for the s7 edge. When I see one that looks suitable it either is too light and falls backwards when you try to use your s7 or you can't get to the home and return keys due to the lip being in the wrong place.
Can anyone recommend a good one? Would be nice if you could use the charging cable through it but not a deal breaker. Thanks.
