S7 Edge Unresponsive - No button combo works!!
Android CN
8
My S7e (Exynos) suddenly stopped working after an overnight update. At first it was stuck on a boot loop, I tried to force reboot it (vol down + power) and the screen went black, with only the blue led light blinking. Eventually that died out as well and now the phone is an unresponsive state. (No button combo works - no recovery mode, no download mode, computer doesn't detect it, but the wireless charger does)
Changing the battery did not work for me, as the phone won’t power on and remains unresponsive. Seems like there could be a problem on the motherboard? Is it even possible for a hardware issue to crop up after an update?? The phone wasn't overeating or having any noticeable issues prior to the update.
Has anyone who's faced this - managed to revive their phones, even if only for a short while? I really want to get some data off of the phone.
Unfortunately, that blinking blue light is often a bad sign -- it could mean a problem with the motherboard or the memory chips. You've already tried pressing and holding Power for at least 30 seconds?
I have and nothing works! What does the blinking led light mean? I just wanted to try rebooting the phone as it was on a boot loop, or if that didn't work try getting it into download mode, but the screen just went black with only the led flashing. Does the whole motherboard have to be replaced you think? I really want to get some data off the phone!
From what I can tell based on experience on the forums, the blinking blue LED is associated with either motherboard or memory failure. If you weren't keeping your important data backed up or synced on a regular basis, then all you can do is bring it to a forensic data recovery specialist (which often costs a lot). Sorry!
If you think the phone worth keeping take to repair center have them run a diagnostic
Would a repair centre be able to pinpoint what component failed after running a diagnostic? Also would running a diagnostic be expensive?
I do have most of the data backed up, but was keeping some things just on the phone, which wasn't such a great idea in hindsight. I just never expected it to stop working out of the blue, all my old android phones still work almost a decade later. Thanks for the suggestions regardless!
You original owner?
It has the original battery?
Yes and yes! The battery has never given me any trouble prior to this though, no overheating and it lasted me close to a whole day with my usage.
It's possible it's your battery, it's going on 4 years they don't last forever, take example your car battery if you stretch it out 4 to 6 years it can stop at any moment without notice.
Most definitely! I'm willing to change the battery and give this a try, but found that this same issue has been plaguing a few other S7 users as well after the last update and others with phones exhibiting the same symptoms have changed the battery and the phones have remained unresponsive. Would running a diagnostic be expensive?
I'm not sure, but you can always get a quote
slackingfred
