recDNA
Sounds like lots of issues. Some people may have them and not even know it like I seldom use video recorder and never use snapchat.
I find that my split screen app keeps popping up like I'm holding down the multitasking button.
Did you ever get a resolution for this? I'm having the same issue. Whenever I try to go into do not disturb settings the settings app crashes.I noticed a crash when trying to get into the Do Not Disturb settings.
This worked perfectly. Thanks!!I did. I opened up those settings by long pressing the DND quick settings from the notification panel. After that, I was able to open up those settings from the regular settings page.
This is still happening every single day. So dumb! Probably something AT&T jacked up.Every morning my screen lock settings are changing from one minute after screen shut down to twenty minutes. What in the world? Seems like a security issue.
It does look like the glass might be lifting some, does it change at all if you press on the area?
No, it does not change at all. It just looks like a smudge but cannot be cleaned so I'm guessing it's something inside.
Water damage maybe?
Nope, hasn't been wet since I bought it, which was about two and a half weeks ago.
