KimJongOMG
It is something T-Mobile allowed I guess.
Do you use the constellations to browse the web?
Very nice. Coming from a Note 5. Seems like the battery is going to be really goodOtherwise, how are you liking the phone? What phone are you coming from?
Ya know: the most likely explanation for not being able to download the browser from the Play Store is because Samsung hasn't updated compatibility for it yet. This isn't a problem if the browser is already installed which is why it's fine with other carriers.
Edit: the last update on the store was Oct. last year. Just be patient and at least wait until it's updated before jumping to conclusions. Use FireFox or Dolphin in the meantime if you don't like Chrome.
You're right.Someone will correct me if I'm wrong but I'm pretty sure last year on the S6s for VZW, there was no Samsung browser. Ever.
That doesn't explain why it would be on all the other versions except the Verizon oneYa know: the most likely explanation for not being able to download the browser from the Play Store is because Samsung hasn't updated compatibility for it yet. This isn't a problem if the browser is already installed which is why it's fine with other carriers.
Is this the one you downloaded
https://forums.androidcentral.com/e...sec.android.app.sbrowser&hl=en&token=eQ8iOEP7
Not compatible with my deviceIs this the one you downloaded
https://forums.androidcentral.com/e...sec.android.app.sbrowser&hl=en&token=Kp8qaOhd
