S7 Edge "Always on Display" with Clear View case problem
Status
Not open for further replies.
Rensu
3
Hey,
Tried out my new Clear View case with S7 Edge and what can I see the "Always on Display" doesn't work anymore with it nor does it show anything at all (practically what it displays is the basic Time, Date and that's it (for several seconds) for example I had Calendar on but not working with new case). After some seconds it disappears and no longer "Always on Display" working but rather just old function which older versions used to have.
Is it some kind of error? Or is there any way around for this? Anyone else having this kind of problem?
Hopefully I explained the problem understandable enough,
Thanks!
Status
banoczky
