Any reason you use it over android device manager?
I can't seem to figure out how to set up find my mobile with Samsung on this device.
There's nothing to set up. I just logged on to findmymobile.samsung.com and everything worked for me. The only real setup I had to do was logging into my Samsung account on my phone.
I went into my phone and logged onto my samsung account, and then went to findmymobile web site and logged in, and does not show my device. Do I need to do something more?
I have no idea what's going on, my phone showed up just fine. I would send in a ticket to CS and see what's going on. If you're logging on to the same Samsung account from your phone and the site, it should populate.
It finally showed up after 2 hours!
I talking about setting up phone in case it is lost. Fin My Mobile is like Find my iPhone.
Does anyone know where I can find the Remote Controls settings or know anything else I can do to activate find my mobile?I'm not able to get this to work either? I'm signed in to my Samsung acount and on the website it shows my device, but it doesn't show as connected. The Help tutorial says to go to Main Menu>Setting>Security>Remote Controls to enable. I'm not finding that anywhere in the S7 menus. Any ideas?
I'm logged in, & can select the S7 from my registered phones list, but it doesn't allow me to track/ find the phone.There's nothing to set up. I just logged on to findmymobile.samsung.com and everything worked for me. The only real setup I had to do was logging into my Samsung account on my phone.
