Samsung Galaxy S7 Edge Issues
YoungASC
4
I have had the Galaxy S7 Edge a few days before the official launch and have notice a few issues:
*Everytime I send a photo to a contact my phone will say "No Connection" even though the message sends successfully
*While using certain apps I've had consistency issues such as on Facebook if I refresh page twice it will no longer load and at the bottom it will say "Can't Connect Right Now" and offers a retry button. On Spotify sometimes it will say that none of songs are available once I try to switch to a second Playlist. On SoundCloud & Sirius XM if you turn the phone display off for longer than 2 minutes the connection stops and as soon as you turn the screen back onto the app, the connection resumes but even when I did that the signal of the app drops every few minutes and forces you to try to reconnect.
*My Email has to also be force closed then re-entered in order to sync (even though I have the sync upon delivery option selected)
*It all seems to be data related issues even though I have strong signal at times of the issues for these apps
*The only way to fix these so far is to force close the apps and reopen them but every 5 minutes or so I will have to force close again. I run through AT&T and am coming from the Galaxy S5 in which I had none of these previous issues on that phone
Has anyone else been experiencing these problems? I'm trying to find out if it's the phone or the carrier with the issue.
Same problem with emails and when i go into stock internet get a message cant connect no mobile data even though I am on wifi connection yet it opens the pages...
