Im loving my S7 edge. I thought marshmallow was supposed to have the DOZE. feature? Is it built into the software? Can you access it at all? I can't find it anywhere.
Yeah it's not an app, it's a background task that helps the battery. You probably won't see anything unless you leave it idle for a couple of hours then check your battery stats.
