A AC Question Apr 12, 2016 #1 what sim card fits a samsung galaxy s7 edge mine is a micro sim ,can it be cut down
Sim Sim Salabim Active member Mar 25, 2016 43 0 0 Visit site Apr 12, 2016 #2 Re: what sim card fits a samsung galaxy s7 edge you can try cutting it down, but I doubt it will work after that. you should probably try to get one from the carrier
A anon(8709382) Well-known member Apr 9, 2016 248 0 0 Visit site Apr 13, 2016 #3 Re: what sim card fits a samsung galaxy s7 edge You could cut it but its not worth the hassle and potential for damage to your SIM or phone. You need a nano SIM card Posted via the Android Central App
dpham00 Moderator Team VP Moderator Apr 23, 2011 30,108 200 63 Visit site Apr 13, 2016 #4 Re: what sim card fits a samsung galaxy s7 edge I cut my Mico sim to nano. Works just fine. Worse case you would need to get a nano sim
