C cassar82 Active member Oct 23, 2016 38 0 0 Visit site Nov 7, 2016 #1 How do I set my s7 edge in MTP mode? I'm trying to connect to Kies3 but I need to set MTP mode please help I'm gonna be using a PC & Mac
Tim1954 Q&A Team Jan 17, 2016 6,924 1 0 Visit site Nov 7, 2016 #2 Once you connect your device, pull down the quick settings menu and tap on the usb notification. The modes will be there
C cassar82 Active member Oct 23, 2016 38 0 0 Visit site Nov 7, 2016 #3 I can't seem to find the USB modes do I have to add it in?
chanchan05 Q&A Team Nov 22, 2014 8,519 0 0 Visit site Nov 7, 2016 #4 You need to be using a USB cable that supports data transmission. Are you using the supplied cable? When you pull down the notification bar, tap on the notification that says charging
