How much memory does Nougat take up on Edge?
csiguy1
115
How much memory does Nougat take up on Edge? Also can you get by with 32 gigs of storage memory?
I can say that the system folder occupies a bit over 9GB of my 32GB S7 Edge with Nougat.
Yes, you can get by with 32GB, Of course, the S7 Edge has expandable storage with the SD slot, so I can't imagine that storage will ever be a problem.
I also use a 32GB Note 5, and I have not had an issue with storage space.
dayssss2
