Need educated advice on magnetic cable for my S7.
congaman59
Active member
Jan 30, 2011
35
Does anyone have knowledge of use of magnetic charging cables. To the extent of daily use and which last the longest. I have tried a couple different brands but I was disappointed in both. Smart & Cool & WSKEN. I work for Instacart, and I have to use a charging brick along with my phone during the day to keep the app from draining my phone. I have had bad luck with traditional cables due to my clumsiness. I have had to have the port fixed a couple of times.
I need a cable that is made well and has a well made insert that will last longer than a week or two.
I have had really good luck using the brand MAGNET QC3.0 from Amazon Not real expensive either, under $12.00
Jeferson de Jesús
