The 8+ has the larger battery, but how much will it be negated by the larger screen eating it up? In the end, will it have battery battery life, or will they likely be similar?
I get about 2h SOT on my S7e. It's pathetic.
You should do a factory reset and restore with Samsung Cloud. I was having battery issues on my S7 Edge but after I did a factory reset battery was subperb
Guarantee you a factory reset will fix it... Also check and see whats draining ur battery from battery settingsI'm on my second S7e for this reason. Battery life was improved back to what I'd consider normal after the Nougat update, but now I'm back down to pathetic.
That's certainly not normal under typical usage.
I agree, and I think I definitely fit in the typical usage category. I've had a bunch of problems with both S7E's I've had. As I've said, I've never had so much hate for such a good phone. Can't wait to get rid of it. Hopefully the S8 is back to the reliability I had with my 2 N7's.
