pankaj981
I did the opposite. I bought and used the S8 for a couple of weeks. While in the in hand feeling is nice and better than the S7 Edge, it didn't quite match the battery use on my S7 Edge (Snapdragon S8 vs Exynos S7E). I ordered the S8+ which I'll be receiving on Monday. The FP placement was a mess on the S8 so I'm pretty sure the Plus will only be worse. Hopefully the S8+ will match the battery life on my S7E. And since the S7E and S8+ are more or less the same width, I would be comfortable with one handed use.
