tigerpierre Well-known member Feb 22, 2011 86 1 0 Visit site Sep 28, 2017 #1 Had anyone else found that the auto brightness isn't working?
Tim1954 Q&A Team Jan 17, 2016 6,924 1 0 Visit site Sep 28, 2017 #2 Mine works fine. Check the sensors on service mode (*#0*#) for hardware fault. Be sure sensor isn't covered /dirty... I find them annoying most times as they dim too much, so rarely use that function.
jacker Trusted Member Apr 12, 2010 427 4 0 Visit site Sep 28, 2017 #3 It works if you go by what it says. It says by YOUR manual adjustments. It then applies those adjustments in similar conditions. So if you're always bumping up the brightness in dark conditions it's going to keep doing it as well. Thereby offsetting normal auto brightness.
Eugene Carroll Member Feb 28, 2017 18 0 0 Visit site Sep 29, 2017 #4 It never works - on any phone. All it does is make you think you're having a stroke or something is wrong with the power. I just adjust it manually.
T TFBisquit Well-known member Apr 23, 2017 171 0 0 Visit site Sep 30, 2017 #5 It certainly works on my s8+, and as said, it memorizes your preferences. So keep bumping it up. If you think it's broken, then shine a flashlight or other bright light directly on it, and watch the slider move by itself.
