- Jul 2, 2012
- 134
- 2
- 0
If this has been posed before, please pardon the redundancy.
I am on an S8+ Verizon. I have owed it for four months without any problems.
Ever since the recent Oreo upgrade, the device takes significantly longer to charge; albeit through a wireless charger or via traditional wall-plug chargers.
Also, the power usage/drain is much more severe than it was pre-Oreo. And, yes, I have run the power optimizer several times. I also have wiped the cache partition several times. I am not what would be called a "power user," by any stretch.
The device does not get hot. Nor has it ever been dropped or anything of that sort.
Any guidance would be deeply appreciated.
Thank you in advance.
