msross
57
I am having trouble with playing music over bluetooth. The music breaks up after the first minute or so....Anyone else having this problem? I reported it with no answer back
Milt K
177
so anyone in the US get the official pie update yet?
The S9 and Note 9 stable pie builds are only for the Exynos-chipsets and have been pushed out in parts of Europe. Not many people use those variants in North America as they're not compatible with CDMA networks.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,586
6,172
113
I figure the s9 US would roll out to the beta users
Abbers727
371
16
It's not lost, Samsung changed the behavior of AOD. Now by default you need to tap on the screen for the AOD to appear for 30 seconds before the screen turns off.
To change this behavior, go into the AOD settings and look under "Display Mode" and select "show always" instead of "tap to show"
Dont worry, I thought the same thing as you or that something was broken 😅
I'll have to remember this.
So there's no longer leave AOD on for a certain amount of time? it's either tap to show or show always?
