What do the pins/screws look like that hold the clasp to the band Gear S
pedalquickly
3
I recently purchased a used Gear S on ebay. I knew the band was broken in some way, but when I received it the only problem is two pins or screws missing. I don't know if they were screws, rivets, or some sort of pin? Anyone know? Thanks!Gear S Clasp Pins.jpg
dabombcra
160
I recently purchased a used Gear S on ebay. I knew the band was broken in some way, but when I received it the only problem is two pins or screws missing. I don't know if they were screws, rivets, or some sort of pin? Anyone know? Thanks!View attachment 208730
Looking at my band, they look like a pin. I can't seem to remove them to be sure. They are not screws and they don't look like rivets.
priceslss
330
you would probably come out better just getting another band... Search on ebay or amazon for a samsung gear s dummy band or samsung gear s dummy watch (that includes a band) if you can't find a stock one cheap. Those are usually $20 or so but the dummy models use real bands.
123dzo
