Contacts drain battery
  • Start date Start date
A
Android Central Question
The battery of my Gear S2 lasted a whole day until Friday, starting the day, it lasts 90 minutes...just like that.
Checking the battery log, I see that contacts use over 50% of it. I don't know if it happened before, but it sure happens know, right after an update.
I don't think it the battery, because it lasts over a day on standby mode.
I need help here. Thank you
I don't have that watch, but have you already tried a factory reset, then re-connecting the watch with the phone and re-syncing everything? This process is relatively painless on Wear OS watches, but I don't know what it's like on Tizen watches.
The issue is Contacts continuely syncing on phone. Turn google contacts sync off. Restart phone. Turn contacts sync back on and Walla! Fixed! I also opened google contacts on my pc, it appeared to be syncing also. Watch still has 82%,last charge 18hrs ago. Contacts usage 21% & watch faces 16%. HAPPY DAYS!
BobCat6767
