Question about stock system toggle widgets
korsjs
24
When I first got my nexus 4g it had five toggle widgets on the last screen on the right hand side. Wifi, Bluetooth, gps, etc.
I removed them when I first got the phone. I can't seem were to find how to put them back. It does not come up when you press and hold the screen to bring up the widgets options.
Any idea how to get the stock toggle widgets back?
Long press on the homescreen.
Select Widgets
Choose Power Control
Then it will give you the option to select how much screen space is taken to make the widget. Select the stock setting it provides and click OK.
alejandro109322
