Pop up Issue on Phone - HELP!
jhill0224
16
For a while now I've been experiencing this green star pop up in my status bar and when I click on it it has a message and takes me to rightonmobilecenter.com/extension goes here (changes each time) ... Anyone have a clue what program this is attached too??
Download Addons Detector (LINK) and run it. Then on the list click to filter by "Push Notifications" uninstall any programs on that list and also, if you don't mind, list those apps here so we can all know what to avoid.
Thanks for the quick reply! Ran the program... The culprit is Blogger-droid
(shame, I'm going to have to look for another app that allows setting the post to be posted at a future timed date - If anyone has suggestions let me know!)
i had an app called bloat freeze and it was the culperate of that. if you have that app uninstall it. it was removed from market due to their spam. I installed Antek App Manager instead to freeze my bloatware
I downloaded add-ons detector and it worked I got a Mario kart game from 4shared.com and that's what it was
As it was iheart radio was the culprit.
Have deleted and might reinstall later after sending them a email hoping for an explanation.
Hey all, I recently started getting this issue as well, but after running the outlined apps to check for pop ups I found that none of them are causing the pop ups.
I got some screenshots of the pop ups though:
Does anyone have any ideas?
mekonnen Ayele
