1 week later...
Twitter actually has push notifications for Tweets/Mentions/DMs. The rest don't. That along is enough to make the Official app better by default.
As for the sound, maybe you just can't hear it out of the speaker? X-D
Lol..no that's not it. It just doesn't make a sound, and I've tried them all.
Sent from my LT28at using Android Central Forums
Not sure what that issue is, then, other than to do the obvious and tell you to check your notification ringtone :-(
Also i have pics stored on the internal memory,is there a way to move them to the SD card?
You should be able to just plug into your computer via usb. This will add the Ion as an external drive in explorer. Then just dig down into your folders. You can use the gallery on your phone to find the exact directory of the pics. Personally, I just use swiftp app on the phone and filezilla on my pc to wirelessly transfer the files. A bit slower, but easy if not a little technical.
I just bought this phone (free at best buy right now), and I have to say it's the most underrated phone on the market. The size takes a little getting used too, but what's not to like? Put ICS on it last night, then added my normal apps. Screen is much better than I expected, I came off a galaxy s1 with amoled. Viewing angle not as good, but I never hold the phone like that when using it. Looking at it dead on, it's amazing.
I'll have to report back on battery life, after I'm done playing around with it. But so far so good. Didn't notice it being any worse than my 2.5 year old battery in my galaxy.
Sexygirlsse
