1750 or 3500 battery
taguluchi
177
11
I am having a tough time deciding on which one my concern with the 3500 is getting it with the siedio innocase rugged case is that it will be bigger than i like, but on the other hand is the 1750 really worth it? if i get a couple more hours with the 1750 I would be happy with that but I wanna get some recent user prespectives, I am open minded on anyones thoughts on pro's and con's with both .....thank you for your input in advanced
Your going to spend the money on it so why not just go with the 3500,buy from Amazon, if you don't like it return it for a refund.
I just got my 3500 yesterday from amazon with free 2 day shipping and I love it.
Sent from my PC36100 using Tapatalk
Is the 3500 bulk more than you thought it would be
Actually its less.
If you look i got a post on this board underneath this one, with a link to before and after pics.
Why spend that money on something for a hour or so extra?
Might as well get the real deal power house for unlimited power.
I have the 1750 battery and it gives me plenty of battery life. I went from 12-14 hrs on a charge to 1 day 9-10 hrs with moderate use. It did add a little bulk to the phone, but I don't find that it's excessive. I don't think you'll go wrong with either one. I hope you find this helpful.
really?
do you do anything with your phone? or is that just idle? I tried with the stock battery and couldnt make it 10 hours, though i was using it for emails and making calls. I got the extended battery and love it. You dont have to constantly turn services off. You get to fully use your phone, one of the reason's i got the phone was because of everything it can do.
I ordered the 1750 battery from Seidio right after I got my EVO several months ago. I have used the 1750 and the factory battery, and I have a hard time seeing any difference in battery life.
If you truly want longer battery life, go with the bigger battery. You might be disappointed otherwise.
I've both a couple 2000 and 3500 batteries from overseas for dirt cheap off ebay. All tested good on a cadex machine and run well in the phone. 4 batteries, a back cover, and a couple chargers was around $30 bucks.
Actually its less.
I agree with the above statement. I was prepared to have to deal with the extra bul but was pleased when it was installed because it wasnt as bad as i figured it would be.
Get the 3500 mAh you wont regret it.
Just got the 3500 yesterday, and glad I didn't settle for less. The extra size in the back is great for stability when holding and typing in landscape. Just get one.
I did this morning had to order it from seidio online, amazon didnt have the seidio rugged case in stock so i order the battery and the extended rugged case ....I have the innocase active limited edition which is similar to the rugged ...does anyone have the extended rugged case?
godef
