2.2 (Froyo) is rooted! Talk about it here
Status
Not open for further replies.
Thanks Dex, RC2 is amazing. Never thought root could feel so good.
Gotta love google open source :)
No prob dude....
I loved CM6 Until I cooked myself some S3ns3l3ssn3ss haha...
I'm a Fan of both Sense and ASOP so I need to have both... Im Greedy
Am I the only one that scared ****less to do this? I feel like I'm about to go skydiving lol...
I went Skydiving on July 18th... I actually pulled my Tandem buddy out of the door with me...
No fear man Just do it!!!!!!!!!!!!!!!!!!!!!! :mad:
i had to type cd C:\android-sdk-windows\tools then it let me do the command prompts..... i did roll back to 2.1 now downloading simpleroot2.1 loving this stuff guys thank you for the prompt help i appreciate it.
if you haven't decided on a ROM yet use the AC ROM in the Sticky section. it's super.
use simpleroot. i have it linked in a previous post. can't remember which one.
found it!
why don't link backs work?
anyway, it's post #51.
or
http://evo4g.me/downloads/OTASimpleRoot.zip
I did the downgrade successfully as posted on XDA. I stopped after 2.1 booted successfully, right before the unrevoked instructions. I proceeded to use the SimpleRoot method posted here.
This app has 4 steps... and the last step is supposed to flash a rom... but the hboot on my phone says Main Version is Older! Update Fail! Any help on this?
which rom are you trying to flash, if your trying to flash CM, you need an engineering bootloader.
the step 4 of this application made my phone go into hboot and it says to "wait until the device prompts you to install update" but it says update fail!
not having your phone to look at . . . it sounds like you didn't successfully revert back completely. hate to say it, but you may have to re-trace your steps.
go back and re-do the:
Code:
cd /data/local
./flash_image misc /sdcard/mtd-eng.img
by itself and if that doesn't work. start from the beginning.
Code:
cd /data/local
I noticed that the app missed copying the flash_image file over to the sd card, so i booted back and copied that file and retried the step 4. now it is updating. thanks.
So far so good. The updating process bypassed the TP part. Not really sure what it is for, but it's rebooting now. Wow... the Sprint splash 4G video is replaced by one that says HTC quietly brilliant. LOL!
I did the clean root files and afterwards, I did the flash recovery using RA recovery... and the phone rebooted to a exclamation sign. What have I done wrong?
EDIT: I pulled the battery, and it booted back again. How can I confirm that I have the RA recovery?
hmmm, you could phrase that differently for me please.
so you deleted the flash_image after you were done, but did you ever use the simple root to root the phone after you reverted back to 2.1 completely?
Status
alexajamez
