2.3.9
If you want to try out the thundercats and you did get stuck there a simple battery pull and restore of a backup would be the way to go. Good question though.
LOL i made them logos ;) I just wanted to go back to 2.1 then to ota 2.2 and root and rom and theme again. Its on 2.1 now and its dl ota 2.2.
Just pull battery on the boot loop.........you'll be alright
(enable private messages)
That did not work. After the 3rd sbf I remembered last time I used sbf I did a full wipe and that fixed it this time too!
Only if you backed them up with a app or pulled all the apk files from you phone and saved them.
is there any way to restore allll your apps after you clear cache and data?
you need to go ahead and get titanium back up . you can backup all data , all system apps , system data everything . all you do is onle click backup , and then one click restore. its a great app , very user friendly.
not sure about the 2.2 on rom. I just did the ota. then i went back to flyx and it shows as 2.3.9 again but I guess its really now the ota
Slightly off track question:
Got mine rooted (2.2.09 leak) and now what to do for next update? sbf2.1 and OTA or is there any other way to OTA? Thanks.
If on leak sbf back to 2.1 then check for update in the phone and dl and install. Might be zips around but the phone dl is simple.
Sent from my DROIDX using Tapatalk
Reactions: mp33er
As a noobie, just to make sure, sbf2.1 can be used on ROOTED 2.2 leak, right? Thanks, again!
Yes I just did this last night. If on the leak use 2.1 sbf. Once that's done dl the update in the phone to go to ota 2.2.
sahnyuakm
