2 days old lg flex screen problem
Mohamed Omran
6
After only 2 days of a brand new lg flex 2 my screen turned as per picture I don't know why and how to fix it as I bought the phone from abroad can any one help me please to fix it is it a hardeware problem or software , I will try to send it back but I would like to take a chance to fix if possible please help [BOX]image.jpeg[/BOX]
I bought it brand sealed new after only two days of normal use and downloading only from the google store apps this happened and I have no clue of reason
The same thing happened to mine a few days after I got mine from sprint. All I did was turn it off, take the battery out, and wait like 30 minutes. Put the battery in and turn it on. I hope this helps.
Flex 2 can take battery out? That's new to me i tought it had non- removeable battery
LG Flex 2 (5.1.1)
Maybe try to do a factory reset and start all over again. I have never heard of this problem before, so I hope this helps. Settings>Backup & Reset>Factory Data Reset.
Posted from one of my many Android devices.
kiki2025
