2% in hour of use?
i suffer no hardships doing this -
Battery Tips for Android
1. Toggle off GPS, BT, NFC, Hotspot/Tethering. Toggle on only as needed. (Switch to "Battery Saving" Mode).
2. Display Brightness - Turn off Auto Brightness and Reduce Setting Bar to Minimum Acceptable to you.
3. Sign out of any unused Google Services like G+, Google Now, etc.
4. Disable Location Reporting/History.
5. Beware of constantly syncing in background Apps and Bloatware like Facebook, Twitter, Google News and Weather, Google Currents, Non-Push Email, etc. Set Sync interval for every 1 hour or more and change settings to stop the syncing of data you don't need. Delete the Apps you never use.
6. Turn Off Hot Word "Hotword Detection" Always Listening Mode in Google Search if you don't use it.
7. Turn Off Auto Camera/Photo Upload or at least set it for Upload on WIFI Only.
8. Turn Off Vibrate on Touch for Display, Keyboard, etc.
9. Turn Off Touch Sounds and Unlock Sounds.
10. Don't use Live Wallpaper. Use a dark wallpaper if possible.
11. Set Display Sleep Setting to 2 Minutes or Less.
12. Set WIFI to Always stay on during Sleep if you regularly use WIFI.
13. Uncheck "Always Scanning" in WIFI settings.
14. Turn Off Always Vibrate in Gmail/Email.
15. Be careful of using too many Live Widgets and what/how often they sync.
16. Set MS Exchange Sync at 30 Days or Less.
17. Do NOT use a Task Killer App or Battery Saver App.
I have 80% of this list turned on, and I still average on a single charge 1 day and 17 hours of battery life...
The only question I have is on number 12, I use WiFi all the time, but why would I want to keep it on durning sleep? Maybe I'm getting my definition of sleep confused. Do u mean like during the day when the phone is turned off and in my pocket? Would that be considered sleeping? Or during the night when the phone should be sleeping because no use in a certain amount of time?
Throwing it on the charger now. The battery is at 50% with 14 hours and 24 minutes with 4 hours 49 minutes of screen time. This phone is absolutely the best phone ever. Just wish I could afford like 4gb of data so I can axtually use there LTE more when I don't have WiFi to connect too.
"sleep" means when the display is off and the phone is in stand-by. while it is in stand-by there is still background syncing going on and WIFI uses less battery than cellular.
That's on track for 50 hours, the Maxx advertises 48... 2% drain in an hour of using it seems pretty much the expected value.
ShifaAttia
