2 mysterious problem - key vibration & screen
kermitshor
Hello,
I bought a new Lg nexus E960 few days ago (my first android device after years with blackberry)
at first everything was good, i downloaded some apps from the app stores, and one app not from the app store to try the full version)
I think the first problem started after i installed one of the apps: when someone call me i can see only part of his photo, only the upper part is visible about 25-30%, the rest is black and in the middle the answer icon: press for 3 option, message, answer, reject.
The problem is that most of the photo is not visible, i guess it could be solved by downloading some app for call screen.
even when i removed all the apps from the device, and from my appstore account, and i wiped the device i still see only part of the photo when someone calls
second problem started after the second time i wiped my device for the second time and it is very annoying:
I can't cancel the vibration when i type in the phone. ( the first time i had the phone i went to home->settings->sound-> and i Unchecked "vibrate on touch" and i didn't have any vibrations when i used the phone
when the box is unchecked the vibration occurs on typing (when i use keyboard - sms, chrome, mail.. ), but it doesn't occurs when i navigate the phone, if the "vibrate on touch" is checked, it vibrates when i navigate and type... at the begging after i unchecked it didn't vibrate at all, not when navigating, and not when typing. so i don't know how this nagging bugs started or how to solve them
can anyone help please? even with wiped device, when i don't even load any settings or sign to anything i can't cancel the vibration
I cant remember exactly but I think that normal for the photo to be cut off. Also, you disabled vibrate from the settings not vibrate from the keyboard settings. If you go into the keyboard settings you will an option to disable vibration feedback
Kerry Waugh
