2150mah Battery - Do I need to calibrate phone??
rugbyua9
457
22
Ok so i got the 2150mah battery today and charged it to full. I am using BatteryTime Lite out of the marketplace as a widget on my homescreen to get a % .
What i noticed right now is that when my 2150mah is in and at max charge, it still has all the same "Estimated time remaining for: Idle, Talk, Video, Audio, and Websurfing" as if my stock 1300mah battery were at 100%. Obviously with the 2150mah those should be bumped up quite a bit from the stock battery.
Is this a widget problem, where they preprogrammed the time remaining based on % of power left?
Or is there something I need to to do to the phone to make it recognize that its a 2150mah battery and not stock 1300mah?
****y app. I don't think it likes the incredible..
Sent from my ADR6300 using Tapatalk
I just figured it out!
They do use a % based on mah so when you go into settings you need to do this.
1.) Go to Settings (in the widget)
2.) Go to Phone Selector
3.) Scroll all the way down and select Other.
4.) Enter 2150 into the field for mah.
5.) All done!
Britjetpilot
