You don't need the external charger unless you are anal about it and want it to last the extra couple of hours. Plus, not sure if you got the seidio 3500, but the battery cover fits very tight and it is not something I would want to be removing daily to charge the battery.
I have always just used the original charger and get plenty of life out of the battery (36+ hours at least).
