4.1.1 build 9.8.1Q_39 download and findings
You might need to factory reset. My volume rocker works as usual. None of the limitations you describe.
Well I did a factory reset on my phone and tried to reinstall the update and it failed again
Sent from my DROID RAZR HD using Tapatalk 2
If rooted, Did you delete any apps? Freeze any apps? If so, you have to replace them, or unfreeze them, or the uprade will fail. If you happen to use SAFESTRAP, then you have to uninstall that or the upgrade will fail.
If all else fails, you will have to FB back to original ICS, and re-root, reinstall the OTA's, and then reinstall all your apps again.
Thanks does anyone know where I can get the zip file to flash back to ICS so I can start this process over again? As far as I know I haven't deleted any apps I did freeze them but went back and unfroze them to do update. I've even tried to remove super user in file system but it just tells me its a read only file and can't be removed.
I used these instructions: Restore to stock factory firmware and unroot Droid RAZR HD & Maxx HD (XT926) | AndroMods
- - - Updated - - -
I used these instructions: http://www.andromods.com/tips-trick/how-to-restore-stock-factory-firmware-unroot-unbrick-droid-razr-maxx-hd-xt926.html
r3dpuk3
