4.1.2 JB for my Maxx....
Re: December 24 Update?
Saw someone on the VZW forum saying it had issues? Anyone here seen that/issues...quote below is from vzw site.
Sent from my DROID RAZR using Android Central Forums
bucrane bucrane replied replied 2 hours ago 2 hours ago
I got this update this morning(around 11am PST)and I got this update this morning(around 11am PST)and installed since it was asking me to do it. It was a installed since it was asking me to do it. It was a CHRISTMAS EVE NIGHTMARE!!!!!! CHRISTMAS EVE NIGHTMARE!!!!!!
looked fine but my phone was in "safe mode" for a looked fine but my phone was in "safe mode" for a while so I had to reboot my phone to exit from the safe while so I had to reboot my phone to exit from the safe mode a couple of times. It also disabled the language mode a couple of times. It also disabled the language and input function so the google Korean IME doesn't and input function so the google Korean IME doesn't work anymore. (This means that I can't reply work anymore. (This means that I can't reply Christmas greetings / seasons greetings back to my Christmas greetings / seasons greetings back to my Korean friends in Korean anymore. sigh...) I did Korean friends in Korean anymore. sigh...) I did system restore to set my phone back to factory system restore to set my phone back to factory settings but no luck. If it was not "planned" or "official" settings but no luck. If it was not "planned" or "official" Jelly Bean update, verizon wireless should be Jelly Bean update, verizon wireless should be responsible for this accident and release a fix patch responsible for this accident and release a fix patch as soon as possible as soon as possible
Looks like this person has bigger issues like how to write basic English
So, this side loading deal; Is it reversible? I would like to try an actual update of JB, not just a ROM, but would like to maybe go back to ICS just in case.
I have read that there is currently no way to get back to .211 (ICS) after making the jump to 98.72.8 (JB). There's a good dev community for this phone though, so I'm sure something will pop-up eventually.
I pulled the update from online, put it to the SD card and had zero problems. Love the new notification pull down and Google Now.
On version 6.16.215.XT912 - I've downloaded the Blur_Version.6.16.211.XT912.Verizon.en.US.zip and placed on SD - can I install this update? - Never mind, Using Matt's utility, I went back to 211 and manually installed, real nice JB now...
Same here. Took about an hour but zero problems.
Sent from my DROID RAZR using Tapatalk 2
Smooth as butter folks. No complaints. Stock keyboard has been improved as well.
Yes, very smooth and fluid from screen to screen. Only one minor complaint so far. The "Sticky Notes" widget is gone from this update. Not a big deal but I did enjoy its convenience for quick note taking and reminders. I'm sure there are many replacements in the Play Store but that's not really the point. I was using it and now I can't. Otherwise, I'm very pleased with Jelly Bean.
Is the UI still five screens or has it switched to the RAZR M, HD and MAXX HD UI, where you swipe to the left from home for quick settings and all your homescreens are to the right of main?
It is still five screens.
How is signal quality? On ics mine has been somewhat unstable.
Had to revert back to 4.04 stock (I used the Droid Razr Utility 1.82), then sideload the upgrade. Once done, smooth as butter... Loving JB on this phone now. I actually like it now. I liked it with gingerbread. I felt the ICS upgrade wasn't that great. Phone felt slugish.
I got the JB update yesterday. Accidentally downloaded and installed without thinking. Looks a lot like Windows mobile, which I despise, and causing me some annoying, albeit minor, issues. Here's a list so far:
-Separated my joined contacts.
- Isn't syncing FB properly with my contacts.
- Contact pics are all pixilated and blurry.
- Text message occasionally won't show 'Compose Here' box.
- Wifi disconnects, turns off, and turns back on randomly.
-Favorite Contacts widget is completely borked.
- Lots of presets for app usage (especially using Gmail instead of native email app) have been erased.
That's what I've got so far. Going to clear cache and see it that helps at all. Will report back.
installed from online.. Works great didn't even need a reboot or cache wipe!
Smooth transitions
Fast and more responsive
New gallery is awesome
Google now and new voice search are great
Love the new notification bar
I guess there isn't an official change log :
Abheetha Athukorala
